| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
viper lock and lights problems
K so I got the remote start working finally on my truck, and now im having other problems. First of all, the parking lights wont go off, it seems like the correct wires are hooked up but the viper is feeding power to the parking lights all the time. I tried moving and taking out the fuse under the cover but no luck
The next problem is the door locks. The doors will lock and unlock via viper remote only if the harness they are spliced into is not plugged into the VSM Any ideas? Thanks guys! |
Quit pulling your hair out and take it to a shop to fix it.
I have a "GEM wakeup" diagram I can send you.. Check your email...
Well, send me your email and I will send it to you... Thought I had your email already..
Did you open up the little door on the front of the viper module to put the parking light polarity fuse in the "+" position?
i switched it back and forth between both, no matter what, the white wire puts out 12v
That white wire should put out 12v only if the fuse under the cover is set to positive. It shouldn't put out anything if the fuse is removed. Sounds like you must have a short somewhere..
It should be the solid white wire on the 12 pin plug and not the H1/4 wire which is white/brown. Did you even hook up that (White/Brown)wire? If you did, disconnect it, it is not needed. |
