dome light out - Ford Powerstroke Diesel Forum
Old 02-06-2011, 01:07 PM
dome light out
If the interior dome light doesn't work when any of the 4 doors are opened, the bulbs "look" good, and the fuse is good what would you say would be the problem? When you roll the thumb wheel next to the headlight switch it doesn't turn it on either.
Thanks
Old 02-18-2011, 05:57 PM
I have the same exact problem.
Old 02-18-2011, 06:07 PM
pull it. maybe your cab lights are leaking. mine were. fuse never tripped for the dome. what about map lights?
Old 02-18-2011, 06:25 PM
The Tamed Racing Driver
You might have a bad connection in the wires that go to it. It doesn't have a connector but the contact goes through the mounting screw. Or atleast it does on my 99'. Can't imagine they changed it
Old 02-19-2011, 07:51 AM
Yup, the map lights in the back actually work. The outside thrid brake light had holes in the cover, (wrong bulbs I've been told), and it was ugly inside it so I replaced it and now the white lights are always on so I pulled them, third brake light works fine, weird.
