Upfitter switch wires - Ford Powerstroke Diesel Forum
Old 01-30-2011, 04:35 PM
I want to install a switch for fog lights under my reese hitch for the boat. My truck is a 2005 and doesn't have the 4 orange wires for the upfitter switches. On the back of my Fuse panel the harness is missing for the K spot. Is there another fused feed I can use somewhere so I don't have to run a new feed from the battery?
Any help would be appreciated
Old 01-30-2011, 05:40 PM
My manual tells me circuit 29 is a 10A fused line for customer access.
Does anyone know where I can find this wire?
Old 01-31-2011, 08:11 AM
Are you saying that you don't have the factory upfitter switches, or you just can't find the four wires from the switches? On my 05 as soon as I removed the four bolts holding the fuse panel in place and pulled it down the harness was tied up right behind it. It was maked with a list showing the amp and color code for each switch. Not really sure from your question
