| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
pac swi jack
anyone installed one of these on a 6liter.. Im installing a clarion dbl din and need this for my steering wheel controls. where is the wire/harness located that you tap into for the power of the steering wheel buttons?
Typically you would tap into the red 12 volt switched on the radio harness but I guess any switched would work. The control wire to tap into is the lt/blue w/red wire in the #24 connector, number 18 pin slot under the dash at the base of the steering column.
It's been said direct grounding of the PAC unit to the chassis (under dash) seems to lessen problems. 2005 F250 Wiring Info |
