| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Amp Question - Dumb
Does it matter what battery I use to hook up my amp? Is one more critical to our trucks than the other?
It doesn't matter
Cant wait to get my little sub going! |
There should be a distribution block on the driver's side behind the battery (toward the firewall). That's what I've always used
Don't do this. Go straight to the battery and use a fuse.
Why do you say that?
Every wire has a maximum capacity over a given distance before it heats up and the voltage drop becomes too great. The factory distribution block is fed by a wire sized to handle whatever Ford decided to connect to it. Most amplifiers can draw more current than that wire can handle, especially while other loads are present.
To put it another way, think of the battery as a water tank. The wire to the factory distribution block is a garden hose and the factory loads are drinking straws connected to the distribution block. The garden hose can flow enough water to supply any combination of the drinking straws with as much water as they can use. Now you come along and add an even larger garden hose to the distribution block that utilizes a variable amount of water (volume). As you turn this nozzle on this second hose, there is no longer enough water flow to supply all those little straws. |
