Heater blows cold - Ford Powerstroke Diesel Forum
Old 01-04-2011, 11:30 AM
Heater blows cold
I have a 2005 F250 with the 6.0L. The heater is the electronic climate control but is not warm and does not get warmer the higher you set the setting. All functions work fine (def,floor,vents) It changes back and fourth no problem. It just does not get warm....
Old 01-04-2011, 11:33 AM
sounds like you got bad head gaskets to me, thats one thing that goes when your head gaskets do
Old 01-04-2011, 11:36 AM
Obsessive compulsive
What is your actual coolant temp when warmed up? If your gauge is not reaching half way up, you probably need a new T-stat. Does it seem to blow warmer when you put your foot into it?
Old 01-04-2011, 11:58 AM
Send a message via AIM to troid123
OP, check your ECT and go from there, I would guess your t-stat needs to be replaced...
Old 01-04-2011, 12:49 PM
first thing , check to see if you even have any anitfreeze, my truck did the same thing and i checked the antifreeze and it was pretty much empty lol yes i know lack of maintenance on my part but i filled her up and heat worked like new
Old 01-04-2011, 01:04 PM
Check heater valve on the heater hose under the hood. Verify that it's opening.
Old 01-04-2011, 01:11 PM
Almostdunfukinwidit
First check your coolant level.
Second if its full check ECT at operating temp. I dont mean using the existing gauge.
Third if ECT doesnt reach at least 180 change the tstat its bad
Fourth check the blend door actuator.
Whats the ambient air temp where you are?
Old 01-05-2011, 06:27 AM
Thanks for all the responses. My coolant level is full. I live in northern IN. and its about 10-30 degrees these days. It does not get warmer the more i use the throttle. After the truck is good and warm from driving, it feels luke warm coming from the vents only if i leave the fan on low. If i turn the blower up it just feels cold. Recently i had an egr delete installed because the egr cooler valve went bad.
Old 01-05-2011, 06:44 AM
Welcome to the org. Were in northern indiana are you? If you are near valparaiso I can hook up my scangauge II and check the actual coolant temp. When I get my truck back next week. It's in getting head gaskets and studs this week and my scangauge is in the truck. P.M. me if you need a hand.
Old 01-05-2011, 12:06 PM
Almostdunfukinwidit
Get a cold front
