| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Radio and windows dont work
Every once in a while, when I first start my truck (05 F350 Utility Body) the radio and power windows dont work. After about a minute with no rhyme or reason, they work again.
I am having the same problem.
My 05 F350 6.0 Powerstroke radio and power windows willl not activate for sometimes 3-5 minutes depending on the outside temp. Then walla. This happens only when the outside temp is under 50° F. I'm searching for an answer too.
I have a 05 Superduty that has a similar problem except my windows and radio and lighting stopped working completely, and have been for some time. I had a blown # 42 fuse and whenever i tried replacing it the fuse blew immediatly upon making contact. This happened even with the ignition turned off. My truck is currently at the ford dealership getting the problemed fixed. Supposedly in my case it was a bad instrument cluster that all three of these systems ground through. I had them order the new cluster ($540) and they should be installing it and have the truck ready to be picked up this evening. We shall see......
Cool, let me know what happens at the dealership. I think my assumption was that it was the GEM module under the dash. I heard the windshileds leak a little tiny bit that drips directly on it.?? Who knows though. Good luck
Correction it is the # 41 fuse, I hit the wrong button. I went to pick the truck up at 5 like instructed by the guy at the service counter and apparently even after replacing the gauge cluster it is still blowing the fuse instantly. He assures me that whatever the problem is that it did fry my gauge cluster and i needed a new one although every gauge and all lights work. I'm not a electronics guru by any means and kinda feel like i may have spent a lot of money on a part I didn't need. Any thoughts on this would be appreciated..... Truck should be done tomorrow tho
i had a friend who just got his fixed, his windows and radio wouldnt work at all, he took his truck in to ford and they found two bad grounds that was causing them not to work, not sure if this is your problems but its a possibility
A few years ago I had the same problem, radio and windows quit completely and the fuse would just blow when I would replace it.
It took the dealer 2 days to track down the problem, it was a shorted out dome light wire in the ceiling. The radio, windows, and interior lights are all on the same circuit for the delay system when you shut off the truck. So for those of you that have the problem just temporarily, find out which relay controls the delay feature and check it! |
I too have Some weird things going on with my truck... Usually when I start it after it sat for awhile.. The instument cluster, dome light, radio, and pwer windows loose connection/communication? and there is times the #2 and #8 injectors give codes p0266, 0284...? runs real rough no pwer if in park and the issue at hand comes into play,, when in gear and driving , no power loss or injector miss? also a code of p115 = short Vpwr in harness of H025-21 switch? code U 0155 IPC intstrument panel cluster controle module lost communication code? one night i came home .. the headlights wouldent turn off with the key out of the ingnition and switch was to the auto daytime running position,, normally they would go out after 10 sec. or so?? NOT
The issue comes and goes driving or idling.. usually when it decides to work after 2 cylces of everything working and then not it all comes back and stays working until I turn off the engine. I hate to restart it agian cuz I have the same issues all over agian. Has anybody heard of such a thing? And could a bad Gem module do this kind of stuff thats happening? or is this more of a bad ground/wire? or fuse issue?
I ve been told a bad ingintion switch could be the problem or a bad wire to the FICM? or possibly need a GEM module? I am at my witts end with this truck.. Not kind to me since headgaskets, egr delete, 2,4,6,8, injectors replaced, different remaned FICM installed, a new battery , a rebuilt Altenator,new ball joints...I BET I FORGOT A FEW ITEMS to many to list..
