Help me soon! High voltage HID question - Ford Powerstroke Diesel Forum
Old 12-29-2010, 05:46 PM
High voltage HID question - fixed thanks - very simple
I'm in the process of installing the retro solutions bixenon projector retrofit kit, and like a *&^* idiot I accidentally cut the wires between the ballast and bulb!
I have my headlights apart and I need to get this situation figured out before tonight because I need to go to work tomorrow.
What's the best way to reconnect these lines? Just power and ground, but as I've learned, a butt connector just fries right up.
Stupid question, but would simply stripping the wires, twisting them together, and electrical tape work the best until I can completely re-do this?
Old 12-29-2010, 05:51 PM
Illiana Chapter Director
Put your factory bulbs back in so you have head lights and then you need to solder and shrink wrap the wires that you cut.
Old 12-29-2010, 06:13 PM
Actually your post reminded me that I have a soldering gun and shrink wrap out back. I am going to give it a shot, but basically this is my last chance without purchasing another projector.
IF I go back after soldering and the light doesnt come on - in your experience, would it be a burned ballast or would the fuse go first? I had heard frying when I stupidly tried a butt connector (which had burns after undoing), so I'm afraid the whole thing is shot anyway.
Old 12-29-2010, 06:15 PM
I'm not sure, I would think the ballast since the fuse is before where you cut. Why did you cut anything at all?
Old 12-29-2010, 06:25 PM
ballast does go first
I don't have a good excuse besides being an idiot. I was rushing the job and had cut the wrong set of leads.
Old 12-29-2010, 06:29 PM
In that case I'm not too worried as well. I can always get another ballast, but my main concern was sealing the headlamp back together and having that out the way. Then I can resolder another ballast to the projector.
Thanks for the input guys
Old 12-29-2010, 06:30 PM
At least you owned up to it. Mine had wires that said you could cut or leave in tact. I just left them alone. Do you HAVE to CUT something on that kit to make work?
Old 12-29-2010, 06:34 PM
Actually, yes. The H13 kit had connections that had to be cut off. Hard to explain, but the guys at the shop were very helpful in explaining it to me. However, I got the wrong end.....
What I was supposed to cut off was the connection to the factory headlight harness. This particular kit didnt come with one that directly plugged in, so I had to cut the low, high, and ground wire and splice to the factory harness.
At least I got that right in retrospect....so far! I seem to be having trouble with the high beams as well. With the one working headlight, it wont come on when I throw the switch. That may be a problem for another day!
Old 12-29-2010, 06:41 PM
Oh Hallelujah! The soldering worked! I cant believe I didnt even think about that. Chalk up another one to the idiot card
