| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Factory Remote Start problem
This is for my friends truck but I'm trying to help him out. The truck is an 06 ccsb. I think it has every option except sunroof. It has the factory remote start, and thats where the problem is. It starts the truck, but then immediately shuts the truck down. Then starts again, shuts off. It just kinda cycles until we use the key in the ignition to stop it from trying to cycle. Anyone had this problem before? Anything obvious to check?
thanks for any and all replys. -Kaleb |
Yes, I had this exact same problem with mine after I had it installed at the Ford dealer. My truck is a '06 as well and I had the Ford factory Gold system(Alarm/Remote Start) installed at the local ford dealer. Problem is that the tach signal (which is what the remote start utilizes to sense that the truck is running) is so weak on these trucks, you need what Ford calls a tach signal booster to bump up the tach signal voltage. Not sure of the exact part number, but it is a Ford part. Here is the technical service bulletin that Ford put out to address this issue...
Intermittent Unsuccessful Remote Start and/or Stall After Remote Start: Some trucks may exhibit a no start condition when using a remote start system. Or, the the engine may start and run for up to five seconds then stall. The start/stall condition may repeat itself up to four times without operator input. The technician should contact the Ford Remote Start Technical Hotline for diagnostic assistance. A tach signal booster, P/N 102818-2, may be needed. Broadcast Message 1722. |
Thanks for the info! I'll let him know, hopefully get this fixed before it gets real cold!
