Turn Signal Problem - Ford Powerstroke Diesel Forum
post #1 of 1 Old 12-18-2010, 01:18 PM Thread Starter
Turn Signal Problem
I just finish replacing the #5 injector and took it for a test drive and when I turned the turn signal to make a left hand turn it kept blinking. Moved the switch to the right but the left turn signals both inside and out were still blinking. The only way they turn off is if I turn the steering wheel all the way to the left. When the signal is finally off if I turn the signal on for a right hand turn as soon as they go off the left hand blinkers will blink until I turn the wheel all the way to the left. Please help. By the way all the posts on here about changing an injector really helped!
captredsquare is offline
