What is this wire doing? - Ford Powerstroke Diesel Forum
Old 12-16-2010, 07:27 PM
There is a random wire spliced into the factory harness on my truck. It has been cut off, but I'm wondering what the wire it's tapped in is for. The harness is mounted right under the steering column and is a blue wire with orange stripe.
Old 12-16-2010, 07:44 PM
back to business
Edit -
No idea, sorry. Is that an inline fuse holder on the wire that's spliced in
Old 12-16-2010, 08:31 PM
yes. The wire has been cut off and does not connect to anything. Just wondering what wire they would have tapped into
Old 12-24-2010, 04:42 PM
That is the ignition wires. All remote starts hook up there, but use a bunch more wires.. That looks like someone tapped into an "ignition on" power wire for some sort of accessory like a CB or something. Hold the other end (the one that is cut off), put a fuse in the fuse holder and test the voltage with the key off and key on. You can just cut it off or use it for an accessory of your own. Just figure out whether it is constantly powered (key off) or and ignition accessory wire.
