| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
I am in need of a wiring diagram of the headlight switch and dimmer switch for 2006 f250 with auto lights and fogs. I installed a new deck last night and I think I pulled a wire loose on the back of the switch because my headlights will work but my running lights and dash illumination lights including instrument cluster will not light up. Any Ideas? Thanks so much I need to get this fixed asap
Make sure you grabbed the right power supplies and the dimmer wire I believe I leave off.
If you grab the wrong one it blows the fuse for the markers and interior lights and you end up with nothing but headlights.Done that twice before on some older Fords I have owned. |
Thats a fuse issue
Would the fuse be in the cab or that box in the engine compartment?
IIRC its in the cab
Thanks Ill go check them again right now and let ya know what I find
Problem solved was the exterior lamps fuse. Now I am just trying to figure out how to ground out the dvd player so it will work in motion. Anyone know about that?
they wont work in motion? huh, I would guess a bumb in the road would hurt it.
. put up some picts of it when ur done, one day (like when I hit the lottery) I will put one of those fancy things in.
They wont work because its illegal and unsafe to view while driving but I want it to work for others in my vehicle. It grounds out to parking brake but obviously i cant drive with parking brake on
