headlights dont work need help - Ford Powerstroke Diesel Forum
Old 11-29-2010, 05:37 PM
I recently bought an 03 f250 amd my headlights dont work. Only way theyll work is when I hold the highbeams back and dont let go. Have had the fuse checked on it before and nothing, not sure if its electrical or wiring or whatever. Would really appreciate some help thanks guys
Old 12-28-2010, 06:22 PM
My headlights went out also. I found 2 bad pins in the top connector into the multi funtion switch. I moved my steering wheel up and down and my lites would come back on, sometimes.
Old 12-29-2010, 02:13 AM
Do your parking lights work?
Old 12-30-2010, 06:23 PM
Yes. Parking lights work
Old 12-31-2010, 08:13 AM
I would remove the head light switch and verify you are getting voltage at the headlight terminal on the back side of the switch. If you have power there you will need to follow the circuit until you find the faulty component. Being you said you can move the steering wheel up and down and the lights worked at on time I would suspect you have a damaged wire in the steering column. I would remove the covers for the steering column and double check the wires there too.
Eric
