Need electrical help - Ford Powerstroke Diesel Forum
Old 11-15-2010, 10:57 AM
Feedback Score: 10 reviews
I posted it here because I know alot of you guys know how the wiring works. Anyways my truck is not cranking? I bought new batteries and a new starter and still nothing. Im thinking its the PNS switch??? Is there anyway to by pass it or any other ideas? Thanks I checked all the fuses and relay?? One thing that worrys me is that I bought the truck used and im guessing the Prior owner had a alarm installed then removed it because there is alot of random wires hanging out under the steering wheel
Old 11-15-2010, 11:25 AM
Air Assault!!
Send a message via AIM to MPTonyT
So you kick the key and nothing? no clicking? no turning over?
Old 11-15-2010, 02:49 PM
excatly
Old 12-13-2010, 06:28 AM
So i have been jumping my starter ever since this post started how do you go about testing you ingnition switch?
Old 12-13-2010, 06:48 AM
Just throwing this out there, Could it be a bad safety switch? Like neutral, or clutch etc...
Old 12-13-2010, 06:53 AM
thats what im thinking where is it? How do I change it
Old 12-13-2010, 07:05 AM
I an not real sure how to test it but I think it would be as simple as hot wire in and then hot wire out If I am looking at this right it is the big black switch on the side of your tranny that the linkage is hooked to. Like this one.
http://www.carparts.com/details/Ford...entrepf5064091
If you have a manual tranny, the switch is under the dash some where just like the brake light switch.
Old 12-13-2010, 08:55 AM
thanks alot for your help? I do have a auto ill have to get under there and check it out
Old 12-13-2010, 09:56 AM
Maybe some one else will chime in with more ideas or even how to check that switch. Could be some thing as simple as caroded plug in.
Old 12-14-2010, 10:26 AM
Check your ignition switch also, when you turn the key do your dash lights on everything come on? if not could be either a maxi fuse or your ignition switch
