| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
07 Back up sensor not working ???
My 07 has back up sensors with the override switch next to the 4X4 switch. When I put it in reverse the switch lights up OFF and will not turn on no matter what I do. Anyone had this issue before and know how to fix it ???
Anyone ???
I'm curious as well. Mine does this too. The only answer I got was clean the sensors as they get "gummed up". I cleaned them and still got nothing.
Ihave the same exact thing on my 03, and i have no idea, have they worked before?? Mines done it since i got the truck
My 02' has the exact same issue. I was told to check the wires for bare spots and also was told that if one sensor is out none will work like x-mas lights.
The weird thing with mine is last week I was backing in a spot and they beeped about 5 times and havent work since. That was the only time they have ever worked in 5 yrs of owning the truck |
Your park sensor control module is most likely bad. I took mine to the dealer a few years ago for another issue and got them to check mine out as well (I have the same issue). They traced it back to the module and said it would have to be replaced.
It wasn't worth the money to me to have it done, so I have left them broken since. However, I think you can pick up one on powerstrokeshop.com for a couple hundred bucks |
Here's a link to the module:
Your Premiere Source for Ford Truck Parts and Accessories |
Cool thanks for the heads up on the module. I eras hoping for a cheaper answer. Oh well I will go at it with my volt ohm meter and see what I can fieigure out.
i know this is kinda old but wanna bump and see if anyone fixed the problem. My 03 which i got new does this now. The Off light is constantly on, but when in drive i can push the button and light goes off. but in reverse (when needed) i cant turn them on at all...
I haven't had the chance to mess with mine. It's on my list of things to figure out and fix. Someone on here has to know why these things fail.
