| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Seatbeltminder
I cant stand this damn thing dinging all the time in the 06 Dually I just bought.....I followed what it says in the owners manual to disable it and it still dings....does someone have a different way of doing it? Am I doing something wrong?
find the speaker and cover it with tape. i have an '02 and can cancel it with the seatbelt button but my brother's truck has one you can't cancel and it's covered with tape. can hardly hear it. only way to cancel it is to put the seatbelt on then take it off
i just followed the instructions in the manual and it worked like a charm. maybe you didnt time it right.
go to a junk yard and get a seatbelt clip and leave it in so it fools it to thinking you have your seatbelt on....
I never knew there was a way to disable it in the manual?!? I will have to check into that!
just keeping trying it it will work just takes a few tries
I have this problem with my 99. I know this has been discussed on other threads. But hopefully someone on this thread has some more info. When I start the truck it dings and I hook the seat belt in and it stops. Occasionally it keeps dinging for about 30sec to a minute or so and stops. The other time it dings is when im coming into town 50-55mph and usually, not always, when i slow down to an idle at a stop light it will chime again until i get back up to speed. There is not relation to how fast im going. It doesn't consistently do this. But when it does its annoying. Im hoping someone has had this experience and has a good fix. Any info is greatly appreciated.
Thank you |
I disabled mine by just unpluging the connection under the seat. Just look for the wire that goes up to the seat belt buckle and unplug it.
ive got mad at mine so much just that all i do is hold it down for about 5 seconds or so and its doesn't ding anymore
I tried unplugging the connection under the seat today. But unfortunately it didn't help :\ Has anyone else had this problem. Any help is appreciated. Ive heard of lubricating the door latches and possibly the hole underneath the latch on some trucks have a problem with a switch or something sticking inside?
