Radio help....please asap - Ford Powerstroke Diesel Forum
Old 08-24-2010, 06:05 PM
Firefighter Member
so i just installed a radio/dvd player. Well the faceplate stopped working and found out the ribon ripped...soo in the mean time till that comes in I went to plug the stock one in. Plugged it in and turned the truck on.....nothing. can hit eject cd and it will eject....nothing else. Turn my lights no and its lights come on and nothing else happens....any help would be nice. Thanks in advanced.
Old 08-24-2010, 06:08 PM
Sounds silly but did you plug all of the plugs and the antenna in ? If so , did you pop a fuse ?
Old 08-24-2010, 06:27 PM
Firefighter Member
their is only one factory plug....same one when I took it out....and all fuses look good....i'm completely stumped....
Old 08-24-2010, 06:53 PM
Hmmmm , me too . Does the cigarette lighter work ?
Old 08-24-2010, 06:58 PM
I would say unplug it an look to see if any of the terminals got bent or shoved in . Also are you looking at or testing your fuses ? You cant always see a bad one .
Old 08-24-2010, 06:59 PM
check to make sure antenna is fully seated
Old 08-24-2010, 07:20 PM
Firefighter Member
lighter plug works....looking at fuses...so I guess i'll get some new ones tomorrow to rule that out. atnea all the way in....thanks for all the help. Any input is useful and thanks again.
Old 08-26-2010, 11:55 AM
Firefighter Member
just to update and let anyone know how to fix this.....got new fuses...andd nothing......started going fuse by fuse on the whole panel. #42....Delay Accessory...thats the one that lets you radio turn on. Blown 15 mini fuse....works like a charm now. Hope this will help someone else out.
