Reverse Lights Not Working - Ford Powerstroke Diesel Forum
Old 08-22-2010, 02:56 PM
Send a message via Yahoo to Amarillo-PwrStrk
Both of the reverse lights are out in my 2005 F-250. I put in new bulbs, checked the fuses still not working. WTH??? Any help would be greatly appreciated.
Old 08-22-2010, 03:11 PM
Illiana Chapter Director
Have you checked for power at the plug under the truck on the frame rail?
Old 08-22-2010, 04:21 PM
Will do anything else I should check?
Old 08-22-2010, 04:24 PM
make sure ur gear selector is right over the R or the lights wont kick on
Old 08-22-2010, 04:27 PM
Raging Lunatic
Mine quit working and I had power to the wires under the truck, I think it had something to do with the sockets in the actual tail light. They weren't brite enough anyway, so I installed some tractor lights.
Old 08-22-2010, 04:56 PM
If you have power to the plug but not past the plug to the lights then you have a broken wire or a ground issue. If you don't have power to the plug and all the fuses are good (which you said they were) the you have a broken wire between the plug and the power supply.
