| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
door buzzer
whenever the door is open the most annoying beeping blares until you shut the door. very irritated with it how do i remove this? thanks
subscribed.....
Short out the sensor in the door that tells the computer you opened the door.... Or simply remove the buzzer.
The alarm is integrated into the gauge cluster. remove it take it apart and put a piece of scotch tape over the top. this will quiet it down enough that it does not bother you but loud enough to let you know when you left your keys in!!!
so i cant just find this buzzer and remove it? if so then how? that electronic locking or whatever is just as annoying... almost. i dont have the codes to the key pad yet since i just got it and the thing unlocks itself after i lock it which i did not notice till after my truck has been settin there unlocked for anyone to just take off with it
Also, don't know how much reading you've done yet but these trucks are stupid easy to break into. The door lock itself probably wont buy you 20 seconds. You might also want to look at some threads relating to jimmy jammers or replacing the front handles with the non-key lockable type. |
Just remove the key cylinder on the steering column, pull the clip out, tape it up, reinstall the key cylinder. Done deal.
In the steering colum there is a pink and green wire that goes to the tumbler. Cut it and the door chime goes away. Just remove the two screws on the bottom half on the colum and look for the wire, you can't miss it, going into the top portion of the tumbler.
Yeah thats the same wire that clips on the key cylinder that HeavyAssault is talking about . I
did the same thing years ago and never looked back . I also unhooked the wire under the drivers seat to get rid of the DINGER ! |
