Which wires in the radio harness are for the Steering Wheel Remote? - Ford Powerstroke Diesel Forum
Old 07-07-2010, 06:03 AM
Bought and installed a Alpine IXA-W404 head unit on my '05 F250. It is supposed to be compatible with the steering wheel controls with no adapter needed, just need to splice in to the correct wires on the harness. Only problem is I can't find which wires in the harness are for the steering wheel controls. Does anybody know which color wires on the harness are the inputs for the steering wheel controls?
Old 07-07-2010, 06:46 AM
Air Assault!!
Send a message via AIM to MPTonyT
The blue/red in the 24 pin harness in pin 18 is the only wire. I have never heard of them not needing our SWI-JACK (i work for PAC). Ill do some looking.
Edit: Alpine says........
Steering Wheel Remote Ready
This receiver is compatible with the steering wheel remote controls available in many vehicles. You can take out your factory radio, put in the Alpine, and still have the convenience of operating your sound system from the steering wheel. Ask your authorized retailer for available interfaces.
Let me know if you need one.
Old 07-07-2010, 07:58 PM
Tony, I installed a pioneer avic f700bt in my truck and have lived without the steering wheel controls for a while. Do you know which module I need to make them work?
Old 07-08-2010, 05:15 AM
Air Assault!!
The SWI-PS from P.A.C. will do the trick. It will accommodate the 4 available controls on the wheel perfectly. We also offer the WRI-P that will allow you to use a wireless remote as well (incase the 4 button on the wheel are not enough). It can be used in conjunction with the SWI-PS.
Old 07-08-2010, 06:31 AM
I'll have to get back with you on that. The Alpine has a remote input jack that has two wires labeled remote input out and remote input in. On the same jack there is a hookup for the reverse lamps (for camera) and for a monitor control (rear DVD). I assume that these two leads for the remotes hook into the interface from PAC?
Sorry for all the questions, my first DIY radio install that is more than a factory swap.
Old 07-08-2010, 06:56 AM
Air Assault!!
Those are remote wires for another application. Right next to (just to the right) were those wires enter the head unit there is a 3.5mm headphone jack input into the back of your radio. This is where the SWI-JACK will to plug into the back of the head unit.
Old 07-08-2010, 07:54 PM
OK, that makes more sense now. Thanks for the help. I'll get in contact with you at a later date about the interface. For now I've been using the IR remote that came with the radio and haven't really missed the steering wheel controls. I just hate having things on the truck that aren't doing what they were meant to be doing.
