Excursion Compass Fuel Meter Message Repair - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-04-2010, 07:22 PM Thread Starter
Hi Guys, I have seen a few people that offer the service to repair the Compass Fuel Meter Message Center, I'd been told that there's a very simple way to fix them, do anyone has this procedure? I'd like to give it a try and fix it myself.
Any suggestions?
Turbo Wax is offline
post #2 of 14 Old 07-06-2010, 08:03 AM
nylyon's Avatar
Is this what you're looking for? It's not difficult and should take 10 minutes or so to do. The SMD resisters come loose and need to be resoldered. Hope this helps!
- Karl
2003 F-250 Crew Cab Short Bed Lariat PSD 6.0 Automatic FX4 Edge Insight with EGT Probe. Coolant Filter. All 6.0's need gauges
nylyon is offline
post #3 of 14 Old 07-06-2010, 08:26 AM Thread Starter
Great info! that thread has a lot of good information, thank you so much!! I will try it this weekend
post #4 of 14 Old 07-30-2010, 10:25 AM
Mine was just dim. It even was a slightly different layout for the resistors. I went ahead and remelted the solder to all the resistors and it brightened right up.
Thanks for the info. Someone should get that into the tech forum.
emower is offline
post #5 of 14 Old 07-30-2010, 12:21 PM
Yup. Fixed mine with this also.
obsidian is offline
post #6 of 14 Old 07-30-2010, 03:40 PM
Wait a minute... I went to reset the meter filling up and it dimmed back down again. I wonder if something else is wrong. I might pull it down again tomarrow and try unplugging and plugging it back in again.
emower is offline
post #7 of 14 Old 08-04-2010, 02:03 PM Thread Starter
Finally got around to look into this problem BUT I don't see anything wrong the only sign that I have is the upper left display which looks like? any ideas
post #8 of 14 Old 08-04-2010, 02:08 PM
nylyon's Avatar
In the last picture, see those tiny blocks (I think they say 680 or something like that on them). Plug in your display, then press down on each of those blocks with a blunt tooth pick or something non-conductive. The display should work properly when you hit the right resister. Of course, the display could be shot as well. Does it work at all?
- Karl
nylyon is offline
post #9 of 14 Old 08-04-2010, 02:13 PM Thread Starter
thanks for the tip! yes those are the 680, I will try your suggestion to plug the display and see if pushing on them helps, currently the display is completely blackout, now I see what they said about little hands to fix them!
post #10 of 14 Old 08-04-2010, 06:13 PM
Yea those resistors are the problem.
My display screen looks just like yours with that little burnt spot. Don't worry about it. Try what nylyon said.
obsidian is offline
