2005 F-250 Radio compatibilty - Ford Powerstroke Diesel Forum
Old 06-30-2010, 09:25 AM
I bought a 2005 F-250 with no radio at all in it. I have no idea what radio was in the truck before i bought it. Will any radio option as long as its for that specific year (AM/FM, CD, 6 CD, etc.) fit in this truck and fit the stock ford wiring harness? Thanks
Old 06-30-2010, 12:00 PM
There are some newer radios from '08-'10 radios that need to be programmed to match your truck.
Old 06-30-2010, 01:50 PM
So any 05-07 (AM/FM, 6 CD, Single CD, CD cassette, etc) will plug straight into my truck and work? I am just trying to get this straight before i spend a couple hundred bucks on a radio and it dont work. Thanks for the help.
Old 06-30-2010, 02:24 PM
Yep. Where are you located?
Old 06-30-2010, 02:28 PM
Just get a aftermarket, you should be able to find a cheap 05-07 radio for about $50
Old 06-30-2010, 02:29 PM
Thanks alot for the help. I have bought things before not knowing if they will work or not, and well, it always seems that they dont. I figured it would, but wanted to be absolutely sure before i bought. Im located in south Mississippi. Thanks again
Old 01-31-2011, 06:08 AM
Will '08-'10 CD players work in the 2005 trucks?
Old 01-31-2011, 07:34 AM
04-08 f150 radio's will work as well. might have to mod the bracket just a bit, took me like 10 extra minutes on my install.
Old 01-31-2011, 11:34 AM
So if I change from my single cd to a 6 cd in my '06 will the steering wheel controls work? And how about of I put in a radio from an '08-10? Can't lose my steering wheel controls, I loves them!
Old 01-31-2011, 11:38 AM
Has to be a radio capable of using steering wheel controls or it will not work.You can use aftermarket radois as long as you use the adapter for the radio controls like I did on my excursion.
