upfitter switch - Ford Powerstroke Diesel Forum
Old 06-24-2010, 04:52 PM
upfitter switch
where to get, how much? went to ford dealer today and couldnt find one. when the picture comes up it shows the cubby hole but no aux switches
Old 06-24-2010, 04:53 PM
found on ebay for $124 but i was told i couldfind for cheaper, around $80
Old 06-25-2010, 08:45 AM
ebay has plenty, you can an affordable one.
Old 06-25-2010, 09:02 AM
Almostdunfukinwidit
EBay has em anywhere from 100 to 140 bucks. Thats about the cheapest you will find.
I got damn lucky and got mine for 50 bucks
Old 07-02-2010, 11:53 AM
ok got the switch, $37.50 perks of father in law being ford mechanic.
any how tore into the dash and can not find the harness to plug in, is my truck not equiped with the harness? where do i go from here? there are 4 pig tail wires(red, blue, black and white) under the hood in the drivers side corner closest to the cab. i was under the impression those were the ends of where the upfitter switch
my truck is a 05 f250 lariat any help would be great
Old 07-02-2010, 12:03 PM
Air Assault!!
Send a message via AIM to MPTonyT
The switches normally go to a fuse box behind the glove box and then terminate behind the the fuse panel in the driver side. the 4 wires under the hood are not the upfitter wires. Those are wires that ford ran and connect to nothing on either end so that a hole would not need to be drilled to run anything under the hood.
Old 07-02-2010, 12:12 PM
Did you just get the 4 switches? There is a wire harness that you need that runs over to the glovebox area.
Old 07-02-2010, 12:28 PM
yeap i just saw a write up on installing the whole kit. i need to get the harness to
Old 07-11-2010, 11:02 AM
got everything in and works great, thanks for the help
