Removing door panels for speaker upgrade? - Ford Powerstroke Diesel Forum
Old 06-23-2010, 09:40 AM
How hard is it to remove the door panels and replace the stock speakers myself? Not looking to pay the audio place $150 for install. THanks fellas.
Old 06-23-2010, 09:59 AM
If it is the same as my 2000, just pop off the lens in the bottom rear and the switch panel, remove the two screws in these locations I think there 7mm. Then just lift the door panel straight up.
Old 06-23-2010, 10:04 AM
Air Assault!!
Send a message via AIM to MPTonyT
There are two 7mm bolts. one is behind the lens and the other is behind the window switches. remove both, remove screws and lift straight up.
Old 06-23-2010, 10:28 AM
haha, awesome, i figured it would be more complicated then that. i appreciate it!!
Old 06-23-2010, 10:29 AM
how about the rear?
Old 06-23-2010, 10:49 AM
Also on the front you will need to pull off the little triange plastic piece in the top left corner. It is just held by spring clips so it should just pop off.
Old 06-23-2010, 10:50 AM
Oh and the back is the same. 2 screws but no plastic piece
Old 06-23-2010, 05:08 PM
awesome, thanks man.
Old 06-23-2010, 05:11 PM
I installed my door speakers in 13 minutes.
Old 06-23-2010, 05:26 PM
haha, damn son....door panels off, taking speakers out, installing new ones, and reinstaling new speakers? I am going to time mine now. haha, i know i wont be close to that.
