airbag light stays on??? - Ford Powerstroke Diesel Forum
Old 06-11-2010, 03:24 PM
got a 2006 f250 and the airbag light stays on at the instrument panel.what could be the cause?theres no beeping or flashing.i see no switch to turn passenger side on and off.thanks
Old 06-12-2010, 08:33 AM
You'll need a good diagnostics tool to read the Airbag module codes if it isn't flashing at startup.
Old 07-09-2010, 09:11 AM
Mine was doing that as well. Ended up being a bad clock spring. Took it to a shop to have it replaced, cost me $130.00 total to get it done. Hope that helps.
Old 07-09-2010, 09:33 AM
Mine was also the clock spring. I did it myself. I thunk the part was 85 bucks or so.
Old 07-10-2010, 01:13 PM
I had the same problem with my 04 and had it in and out of the dealership 8 times under warranty for repair which included new clockspring, seat pre-tensioner sensor 3 times, and air bag module. They never figured it out and I actually had to get a lemon law attorney to reach a settlement with FMC. After I settled with FMC I took the truck to a local auto electrician and he found a bad wire under the plastic floor rail on the driver's side.
Old 07-24-2010, 05:55 PM
how/where do you install a clock spring?
