How do you take out the stock cd player? Mine comes out when pull on dash bezel - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-10-2010, 08:20 AM Thread Starter
Quoted: 4 Post(s)
How do you take out the stock cd player? Mine comes out when pull on dash bezel...That cant be right! The bezel wont stay all the way closed so i need to fix it. Thanks
justinp95 is offline
post #2 of 11 Old 06-10-2010, 10:26 AM
RRF985's Avatar
What year?
2013 Ford Fusion Titanium AWD, Deep Impact Blue
Totaled 12-26-12 It will be missed.
2006 F-250SD Lariat CCSB Dark Stone
-ARP head studs
-SCT SF3 w/ SRL+
-BPD Semi-bullet proof kit
-BPD FICM
-High Idle
-Edge Insight CS w/ EGT
-GlowShift Fuel Pressure gauge
-285/70/17 Toyo Open-Country A/T
-4" MBRP Turbo-back w/ cat-delete
-Randy Ellis bar w/ Hella 500s
RRF985 is offline
post #3 of 11 Old 06-10-2010, 10:58 AM
Air Assault!!
MPTonyT's Avatar
Quoted: 5 Post(s)
Send a message via AIM to MPTonyT
If the radio comes out with the bezel then it is either an 03 or an 04. That being said it requires "Ford Radio Removal Keys" which can be found anywhere that sells any kind of mobile audio stuff to include most parts houses.
2005 Ford F-250 CCSB-Lariat-FX4-SRW
SCT - Tunned By Matt @ GearHead Performance
FICM Tuned by Bill @ Power Hungry Performance
AutoMeter Gauge Kit (Boost, Pyro, & Trans)
Diesel Site Coolant Filtration System
Viper 5901 Remote Start / Alarm
Zoodad mod w/ Stealth Screen
4" MBRP Exhaust
MECP Master Mobile Audio/Video/Security Installer/ ASE A6 Certified
MPTonyT is offline
post #4 of 11 Old 06-14-2010, 09:31 AM Thread Starter
Quoted: 4 Post(s)
Oh ya, 2004. Thanks guys.
post #5 of 11 Old 06-25-2010, 09:55 AM Thread Starter
Quoted: 4 Post(s)
OK got the puller pieces from ford, but it still wont come out. How do these things actually work? Should i move then a certain way when there in for what?
2008 F250 King Ranch 4x4
5' Flo-Pro, GearHeads Tune, Coolant Filter
Sold: 2005 F250 King Ranch 4x4
Toyo's, SCT, Blue Spring, EGR Delete ect
post #6 of 11 Old 06-25-2010, 10:28 AM
Air Assault!!
MPTonyT's Avatar
Quoted: 5 Post(s)
insert then (you should feel them click in) then move then the the outside of the radio like you were trying to pry out the radio and kind a pull if you will. I sometimes do them one side at a time especially if it has a tape player. I stick my hand in the tape player and insert the key, move towards the outside of the radio and give a little tug. Trick is to not let the side you already have released pop back in while doing the other side. If the keepers are already jacked up you dont have a choice but to remove the dash with the radio in it. It can be dint but its not fun and feels like you might break something. Hope this helps.
4" MBRP Exhaust
MPTonyT is offline
post #7 of 11 Old 07-02-2010, 05:48 PM
Griz 44's Avatar
Send a message via AIM to Griz 44 Send a message via Yahoo to Griz 44 Send a message via Skype™ to Griz 44
Along the same lines with 2006 king ranch
CD player quit working a year after I got it. Not under warrenty. How do I remove the darn thing.
Thanks
Griz
2006 F-350 6.0 PS King Ranch
Stock 20" wheels w/ 305 55 r20's
Nitto Terra Grapplers
High Idle Mod
Fog Light Mod
No other Mods yet
Griz 44 is offline
post #8 of 11 Old 07-02-2010, 09:44 PM
RRF985's Avatar
I assume you are asking about on your '06 so here it is:
Remove the whole dash piece around the stereo, climate control, and gauges. It's just held on by quite a few clips. Start pulling at it gently and it will come off. It's quite a large piece but just keep working your fingers around it until all the tabs are popped out. (To make it easier I put my trans in 1st (parking brake set) and unplugged the headlight harness. It allows the dash piece to be moved around for easier access to the stereo.) Once it's off you will see the stereo is held in by 4 8mm (i think) screws. Take them out, unplug the stereo and you're good to go.
-ARP head studs
-SCT SF3 w/ SRL+
-BPD FICM
-High Idle
RRF985 is offline
post #9 of 11 Old 07-03-2010, 07:58 AM
Griz 44's Avatar
Thumbs up thanks rr
I will definitely give it a shot. Thanks , it is really cool that someone before has already tried something that you need or want to so.
Griz
High Idle Mod
Fog Light Mod
No other Mods yet
Griz 44 is offline
post #10 of 11 Old 07-06-2010, 08:21 PM
Griz 44's Avatar
It worked and it works
RR, thanks for the info. You are right, that is a rather large piece of plastic. Did what you said and the trim came right off no problems. Lots of wire bundles to disconnect. I found it easier to disconnect the wire bundles to the headlights, pedal adjustment switch, 4x4 selector group, power point connectors, by first pushing the switch assemblies from inside out so you can get to them easier. It took a little frustration first to know that this was possible. Anyway, took the cd player out, blew some air on it , checked for any drive bands that may have come off etc. Couldn't visually see anything wrong with it. Slapped it back together and what do ya know, it works again! Must have been caught in a weird loop or something.
Thanks again
Griz
High Idle Mod
Fog Light Mod
No other Mods yet
Griz 44 is offline
