| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
dash lights
how hard is it to pull the cluster out and change burned out bulbs? i just picked up my 06 350 and noticed the fuel gauge side is out. i guess thats what i get for only looking at it in the daytime
Very simple, Pull on the plastic portion of the dash that surrounds the cluster and it should pop right off, Tilt the steering wheel all the way dawn and then unscrew the tilt lever. gently pop off the dash cover and all the trip computer and light switch will have to be unplugged when you have the dash laying forward of the cluster. Then take I think an 8mm or 10mm and unscrew the cluster at the 4 corners. The light bulbs are held in with plastic retainers. uscrew the retainers by hand, it and the light will come out. pull the light out of the retainer and put a new one in it and reverse your steps. hope this helps.
