No Turn Signals - Ford Powerstroke Diesel Forum
Old 05-30-2010, 01:25 PM
Question No Turn Signals
2006 F350 FX4 PSD
Here's the deal....
I have already replaced the flasher relay, multi-funtion switch, and have checked all the fuses, still no luck.
The problem started one night after getting my oil and fuel filters changed. I got back from the shop and put in the street program from my new SCT programmer (the first time I've ever used it). After that, I have had no turn signals!! Is this just a coinsidence, or could the program have something to do with the problem???
Thanks in advance for anything else I could check before I give up and take it back to the shop $$$$$
Old 05-31-2010, 07:56 AM
Just got back from the shop. It was a fuse that was totally unrelated to the turn signals.
So, if anyone else is having this same problem... make sure to check all fuses. Even if they are completely unrelated to the problem you're havin'.
Aaron
06diesel350
