Headrest Monitors - NOTHING TOO IT!!! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-19-2010, 03:51 AM Thread Starter
SC Premium Member
Rattler-FX4's Avatar
Quoted: 2 Post(s)
That is after sitting for an hour thinking about how the wife's going to kill me when I tell her I have to buy a new set of leathers!!! Seriously, took about 3 hours total and that includes painting them too.
Bought a set of head rest monitors already installed from Amazon. $75 each. Then took them apart, painted and remounted in my seats. Turned out OK I believe....
Link to item at Amazon...
http://www.amazon.com/Roadview-RHS-7-0G-Universal-Headrest-Monitor/dp/B001BA9UQS/ref=sr_1_1?ie=UTF8&s=electronics&qid=1274269534&sr=8-1
Before...
HOLE...
After...
Thoughts??
Take care
............Greg
2006 F250 CC FX4/Lariat * Chrome PKG * 2011 F250 8-spoke wheels * Toyo OC ATII 35x12.5x20 * MOD's (Zoo-dad, Fog light, Homelink, High Idle, THRC) * 4" TB MBRP * SCT w/Innovative Diesel's Xtreme Street Tune * Blocked EGR cooler * Isspro gauges * Dieselsite's Coolant Filtration System * RCX 3" Lift w/2.2 Shocks * RCX dual 2.2 steering stabilizer * * lots more coming ...
Rattler-FX4 is offline
post #2 of 13 Old 05-19-2010, 05:11 AM
Heartbeatracing's Avatar
thats sweet, you should do a writeup on it. I want to do that to my EX
Heartbeatracing is offline
post #3 of 13 Old 05-19-2010, 05:40 AM
Tonka Toy's Avatar
That looks really good. How did you mount it onto the seat?
2005 F350 SRW 6.0L. Exhaust and XCal3.
Tonka Toy is offline
post #4 of 13 Old 05-19-2010, 07:22 AM
johnnyroastbeef's Avatar
yeah describe the process of installing them. that came out super clean IMHO. well done. let us know what kind of head unit you're using to run the video?
NEW TRUCK!!: 2009 F350 Lariat CC Shortbed, 2.5" leveling kit, 35x12.5 R20 Toyo Mud Terrains,
-STOLEN 8/26/10!!!
2006 F350 CC shortbed, 2.5" leveling kit, 295/65/R20 Nitto Trail Grappler M/T's-STOLEN 8/26/10!!!
johnnyroastbeef is offline
post #5 of 13 Old 05-19-2010, 03:39 PM Thread Starter
SC Premium Member
Quoted: 2 Post(s)
Thanks guys. In the 2nd photo, in the top of each corner, you can barley make out the brass inserts. The front panel screws into these and are covered by the small rubber hole plugs that were also painted to match. I used a can of 3M spray adhesive to hold down the leather tabs and with the front screwing on, it also helps hold the leather in place. The head unit is the new Pioneer DVH3200. Running street wires Series 7 y-video cable, 11 foot is plenty, and the output from them looks really good. Especially with their price. The boys sure love them!!!
I started by simply punching a hole in the middle of the seat with a pencil. That was my "NO GOING BACK" move. I then positioned the black inner bracket where I thought it would go. I actually got lucky in that when I did the driver side, I actually started my cut a little higher. But as soon as I saw that the metal frame cut-out (photo #3) was about the same as the inner bracket mounting tabs, I put to rest my real only fear - how to make sure they were just about perfectly spaced so they were a mirror install. Worked out well with this brand of monitors. Cheap brand, but as I said above, they look really good and I'm not hard to please with electronics.
I had to trim about an inch of the foam on each side so the inner bracket fit smoothly but left enough so it was snug. The top of the passenger side had to have a "trim" but not much more than a 1/4". Trimmed out all the plastic wrap they put on the seat to ease on installing the leathers and then pulled the wire down the back, mounted the LCD's and took a few pictures.
On this brand of monitors, the brackets bottom mounting tabs have about a 1/2 spacer tab already installed on the back to "level" the monitor when the seats are reclined in a normal manner.
The paint for an '06 Lariat is Dupi-color's Med Gray Vinyl Spray. About 5 light coats worked very well after lightly rubbing them with 000 steel wool and a quick rub down with iso#70 alcohol.
The rest of my system is an Alpine PDX-5 (spec'ed at 112X4 + 410 X1), Polk 6-3/4 dB's all around (for now), 4 Rockford P1S48's in 4 ohm mono, in my box , and was auto eq'ed with Pioneer's CD-MC20 EQ Microphone. That was well worth $25 bucks from Amazon!!!
Glad this might help some!!!
Take care
............Greg
post #6 of 13 Old 05-20-2010, 07:09 AM
Quoted: 106 Post(s)
Feedback Score: 3 reviews
Any pics of them on with the headunit playing in the background?
villestrip is offline
post #7 of 13 Old 05-20-2010, 01:36 PM
Tonka Toy's Avatar
Does the second picture have the bracket from the monitor installed or is that what is inside the seat when you cut it?
post #8 of 13 Old 05-20-2010, 03:37 PM
bgraff1's Avatar
that looks awesome man! now im going to have to get some....
2015 F350, 4" BDS 4 link lift, fox 2.0 shocks, 35x12.5x20 toyo MT's on 20x10 fuel coupler wheels, bushwacker flares, step back mud flaps, box cover, custom linex'd rockers/flares/bumpers/grille in the new Bronze Fire color, LED headlights, rigid industries dually D2's for fog lights, shocker PASS
bgraff1 is offline
post #9 of 13 Old 05-20-2010, 05:41 PM
HOUTX01X's Avatar
Quoted: 4 Post(s)
another thing to do added to my list!!!
'11 F250 KR
XRT Pro, H&S SX-E turbo kit, NoLimit intake/intercooler
OUO bars/blocks
Ø-EGR,CCV,1993pf
Leveled w/ 35 atII
HOUTX01X is offline
post #10 of 13 Old 05-20-2010, 06:16 PM
tucson stroker's Avatar
Those look great. wona do mine next?
2007 F250 lariat CC LB FX4 PSD.
White leather moon roof fully loaded.
Custom wheels,bully dog outlook monitor, AFE stage ll pro guard 7.
MBRP 4" ss turbo back with cat delete and 5" tip.
ARP'S, EGR cooler delete, fuel cross over lines, SCT custom tuned by Eric.
Proud owner of an 02' Excursion 4x4 7.3 - Rest in Peace Matilda.
Proud owner of an 01' Ex 7.3, 4x4 Limited.
6" lift with Pro Comp Metal Mulisha wheels.
tucson stroker is offline
