05 Switched 12volt lead?? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-25-2010, 05:37 AM Thread Starter
I was wiring my guages and am not having luck tapping the correct wire with full switched power(on whenever key is turned) The only wire I can find right now under the dash/fuse compartment is on when the headlights are on and thats it.
Anyone tap any switched power wires under their 05 dash? If so can you please supply the color/trace ??
Thanks!
madcat6183 is offline
post #2 of 3 Old 04-25-2010, 05:49 AM
05_PSD_Erik's Avatar
Um, I just tapped onto my radio feed fuse. It is the 15 amp fuse in the bottom right corner of the fuse box under the hood, I tapped onto the fuse so I'm not sure on the wire color/trace
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #3 of 3 Old 04-25-2010, 06:28 AM Thread Starter
Thanks. I was thinking about this after I posted too, I have one of the fuse taps so I might just give that a try when I get home. Thanks man.
