| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Retro Solutions - Fog Trouble
Hi All,
Installed my retro solutions HID head lamps on my 2006 f250, very bright. I also purchased the fog lamps. I installed the headlamps first, tested them out prior to touching the fogs and the fog lamps do not work any more. I checked the fuse in the dash, its good, the light on the dashboard comes on, though no lights. Is there a relay in the fuse box in the engine bay I should check? Any thoughts would be appreciated! Thanks, Rob |
Is your key at the "ON" position. The foglights only work when it is on.
Oh and
^^^ What wonder said.
I'm betting that the key wasn't "on". |
I wish it was that simple unfortunately it is when the key is inthe on position, the engine is on... I tried all variations to resolve the issue.
More thoughts? Thanks for the welcome! |
Were your brights on. Fogs cut off when the brights are on (unless you've done "fog light mod")
Is the headlight HID kit a HI/LO setup? Bi/halogen? Bi/Xenon? |
I have not done the fog light mod yet ( i wanted to get this all working first). the HID kit has a hi/lo and is bi-xenon.
You got me thinking that maybe doing the fog light mod would fix my issue... Thanks again, Rob |
I don't know if it would or not, but it's only one small piece of wire tapped in and then ran to ground.
Can't hurt to do it |
