Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 04-23-2007, 10:48 PM
horn/cruise inop-clockspring?
anyone have any clue how to diag a bad clockspring in the steering wheel..my horn stays on from the horn switch being constantly grounded and cruise doesnt work.its the only thing i can think of that could cause both??
its due to me messing with trying to hook my train horns to the stock horn and i think i done it
Old 04-24-2007, 05:50 AM
SNAFUSTUMP‹^›‹(•¿•)›‹^›
Tournaments Won: 1
ill bump this for ya,
not sure on the clock spring, but if you want the stock horn button to opperate the train horns, tie into the wires inside the passanger fender well where te stock horn is
Old 04-24-2007, 06:03 AM
Thats Mr. Oil Leak.....
I don't know about the horn but my 250 worker had a busted clock spring and the key dinger would ding all the time even with the keys out of the ignition. I didn't have any problems with the horn though. Hope this helps.
Old 05-02-2007, 07:31 PM
gonna bump this one more time cause i have the horn unhooked waiting for an idea...its getting constant power and my cruise is still not working...thinkin its the relay but dont know where it is.........plz help
Old 03-30-2009, 06:24 AM
Did you ever figure this out???
Old 03-30-2009, 06:36 AM
Sounds like the clock spring to me. I had one go out and Horn or cruise would not work and air bag light was on. Clock spring is the one thing in common with all. good luck.
Old 03-30-2009, 09:01 AM
I ordered a clockspring. I have no light for airbag ie airbag still appears operational. Is the clockspring still suspect???
Old 03-30-2009, 12:24 PM
Absoultly
Old 03-31-2009, 12:29 PM
I had the same problem with mine...turned out to be the horn contact button and it fried my horns. Cruise was inop too. Dealer told me that I had to replace the whole airbag assy because the horn contact is part of it....$735. I had them replace the horns, plugged the fuse back in and never had another problem. I found that if you go into a carwash and the high-pressure spray comes up from underneath, water gets into the horns and shorts them out, if you use the horn right after.
Good luck.
Old 04-10-2009, 03:38 PM
In my experience repairing total loss vehicles....if the clock spring is bad the airbag light will be on. Does the airbag light self test correctly? (turn key on and it either blinks 7 times and goes out or stays on for a few seconds and goes out).
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
