Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 04-23-2007, 01:56 PM
scotty2280 scotty2280 is online now
dash removal
has anyone ever taken off there dash on the 04 f350 is it hard any info would help thanks
Old 04-23-2007, 02:02 PM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
none of my business , just wandering what you were pulling the dash for
Old 04-23-2007, 02:09 PM
i need to mount my double din tv radio
Old 04-23-2007, 02:17 PM
not trying to be nosy there just curious , so does that mean you need to pull the whole dash or just the part around the radio ,and cluster, , that part is pretty simple
Old 04-23-2007, 02:18 PM
ya thats what i ment is it just clips?
Old 04-23-2007, 04:27 PM
you need radio removal tools , pull the radio out , there is two 7mm bolts right above where radio was , the rest pops out with clips , its easiest to put the park brake on ,put the truck in low 1 , makes it easier to get cover out , unplug headlight switch 4x4 switch and power point and it should pop right out
Old 04-23-2007, 04:49 PM
sweet i just did it it had he two holes on the side of the radio i usd a coat hanger to pop it out. thanks for your help scuffy it just looked harder then it was!
Old 04-23-2007, 04:50 PM
good luck, glad to be some assistance
