LED Taillight Question - Ford Powerstroke Diesel Forum
Old 03-15-2010, 08:34 PM
Feedback Score: 5 reviews
I installed some LED bulbs when I put my smoked factory taillights on the other day. They look great, but I have one problem. When I use the turn signals, the lights blink real fast, just like they do when you have a bulb go out. It does it on both sides. So I'm wondering if I need some sort of different flasher or something to work the LED's correctly. These are the bulbs I put in:
Old 03-15-2010, 08:42 PM
Send a message via AIM to FastFocus
because the filament is broken when your turn signals go out, that is what causes the fast blinking. LED's have no filament therefore your truck thinks there is no turn signal and is making it blink fast to let you know you have a blown bulb. You can purchase a resistor to put in line that will take care of the problem. you have to complete the circuit from hot to ground.
its not your LED bulbs, it happens when you put ANY LED bulbs in.
By the way, where did you get those? they look awesome!
Old 03-15-2010, 08:46 PM
Wow that does look good. you shoulda done a write up on that.
Old 03-15-2010, 08:53 PM
I actually had a guy throw them in for free when I bought a set of taillights. I also put these LED backup bulb "towers" in:
Here is a pic with the LED running lights on and the LED backup lights on:
Old 03-15-2010, 09:00 PM
did you cut ur plastic at all?
Old 03-15-2010, 09:02 PM
Here is a link to them:
V-LEDS RED V-STAR M-SMT TAIL/BRAKE LIGHT BULBS 3157 3156 4057
Old 03-15-2010, 09:03 PM
No, the wings of the light fold to the center to form a cylinder. Then once you put it through the opening, the spring back open to form the star pattern.
So those fit right in?
Old 03-15-2010, 09:06 PM
Found my blinker fix on there too:
3 OHM 50W 4 BULB LED LOAD EQUALIZER RESISTORS TURN SIGNAL BLINKER FIX
Old 03-15-2010, 09:07 PM
yep, fold the wings to the center, hold them while you slid it through the factory bulb opening, and when it slides in they open back up.
