Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 04-09-2007, 03:19 PM
billy2006 billy2006 is offline
keyless entry
truck I just bought has akeyless entry ped on doorbut the dealer did not have the code. Anybody know how I can get the code?
Old 04-09-2007, 03:50 PM
shu873 shu873 is offline
hillbilly keyboard racer
Check your packet with the manual and other documentation inside. It should be in your glove box in a black "bag" with a zipper. I have a small wallet size card in mine with a master code that will always work no matter what its set to. With the master you can follow the procedure to change it to whatever you want. Hope this helps.
Old 04-09-2007, 03:54 PM
there is no card in with the owners manual,is the code anywhere else
Old 04-10-2007, 05:25 AM
TxOutlaw TxOutlaw is offline
I read in the manual its on the computer module??? Don't know where to look for that one...
Old 04-10-2007, 06:45 AM
720Deere 720Deere is offline
I believe that it is up under the dash behind the radio. I have never looked for mine, but that's what I've heard.
Old 04-10-2007, 06:55 AM
Rescuediver Rescuediver is offline
SMOKE ROLLER
There is a factory set code for every truck!!! It is located (I think) under the drivers side dash kick panel. The Ford service center should be able to find it and they can program your keypad for any code you want. The key pad can contain two codes a factory code that can't be reprogrammed and a personal code that can be changed anytime...
