Auxilary Switches - Ford Powerstroke Diesel Forum
Old 02-02-2010, 07:38 AM
Auxilary Switches
I added 90W strobes to my truck. After installing and testing they worked fine. I turned the truck off for a few minutes. Started it back up and flipped the #1 switch and had lost power. I've got power to the other 3 switches and I've checked all the fuses that I know of. Anyone had this problem? Thanks
Old 02-02-2010, 07:53 AM
#1 is a 30amp relay... I wouldn't think strobes would pop that relay... It's located above the passenger side glove box. If you open it up, pinch the sides and it will drop right out of there, the relay box is up inside there.
