Radio harness - Ford Powerstroke Diesel Forum
Old 02-01-2010, 04:15 AM
Radio harness
I added an XM eXpress to my stock radio....but I added the 5v power source to the AUX4 upfitter switch.
It is all working fine except when you shut the key off, AUX 4 shuts off.....I need to find a wire to splice into that will keep it on the same delay as the radio.
Any ideas or suggestions? How about the actual radio power wire?
Old 02-01-2010, 05:44 PM
12 V constant = Light Green / Purple (behind radio)
12 V switched = Pink (behind radio)
Old 02-01-2010, 05:58 PM
How did you wire it into your stock radio?? I want to do an IPOD hookup to mine. BTW, 12VDC on a 5VDC line doesn't sound good to me...might not want to run that like that for very long!
Old 02-02-2010, 04:16 AM
It comes with an adapter to step down the voltage.
XM sells a kit for it, there are also kits like this for adding an IPOD.
Old 02-03-2010, 05:13 PM
do you have the kit part number? How does it work? What type of stock stereo do you have (I have the 6 disc with aux button)...same? I would love to push my aux button on my radio and listen to my IPOD!
Old 02-04-2010, 04:49 AM
Check out the products from PIE
PIE OEM LEADER Manufacturer OEM Integration
They have an interface that will serve your needs
