Brite Box - headlight mod - Ford Powerstroke Diesel Forum
post #1 of 22 Old 01-26-2010, 09:19 AM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
I was thumbing around on Diesel site and stumbled upon this...
http://www.dieselsite.com/index.asp?...ROD&ProdID=358
It allows you to have you brights along with low beams and fog lights. Has anyone done this? I really need more light when traveling in the country at night.
P.S. - I know about the fog light mod, but want the low beams on at the same time also.
04' F-250 6.0L
AFE Stage 2 intake
Liberator EGR delete kit
MBRP up pipe assembly
4" MBRP Turbo back (straight piped) WHISTLE
zoodad mod
Nitto Dura Grapplers
Edge Insight CS
DieselSite Coolant Filtration
Upgraded fuel pressure spring kit
upgraded turbo oil supply tube(solid)
upgraded turbo drain tube
SWAMP's 48V FICM
Rotella ELC
Firestone Ride Rite air bags in rear
draw-tite 30k hide-a-goose kit
scha0786 is offline
post #2 of 22 Old 01-26-2010, 10:43 AM
Calkidd's Avatar
Quoted: 3 Post(s)
It seems this would be easier and cheaper.
Fog Light OverRide
Calkidd is offline
post #3 of 22 Old 01-26-2010, 11:10 AM
Thrill Seeker's Avatar
I bought a whole new fog light assembly and it came with it's own harness and switch. I am hoping that because it's set up that way, the fogs will stay on when the high beams are on because I can turn them on and off when ever so I shouldn't need to do anything like this. I also run older style headlights with high and low in one bulb but I have HID high and low so plenty bright and dont bother me not to upgrade to the 2007 with seperate high and low beam bulbs.
8" Lift
38" Toyo MT's
DIY Traction Bars
Zoodad-AIH Delete-Foil Delete
Adjust. Wastegate
ISSIPRO Performax Gauges
4" TB Magnaflow Exhaust w/ 5" tip
AFE stage 2 PG 7 W/Pre-Filter
Superchips Prgmr 150HP/225TQ
Oil X-over Line
Smoked Lights w/LEDs & HIDs
DIY 3 stage Water/Meth
CCV
6.0 IC
Transgo Shift Kit
Derale Trans. Frame Rail Cooler
Thrill Seeker is offline
post #4 of 22 Old 01-26-2010, 01:06 PM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
maybe that would be cheaper. I'll probably just do that. Have you guys done that?
Are there any negatives to doing this?
04' F-250 6.0L
AFE Stage 2 intake
zoodad mod
Edge Insight CS
SWAMP's 48V FICM
Rotella ELC
scha0786 is offline
post #5 of 22 Old 01-26-2010, 02:57 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
I did the foglight mod like in the link above, works fine. Easy to do.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #6 of 22 Old 01-26-2010, 03:10 PM
Kilroy's Avatar
Kind of an old thread (the linked one), will this work on an '06?
2006 6.0L Harley Davidson Edition w/ Ghost Flames
  • Turbo-back Magna Flow 5" exhaust
  • Reese 22k 5th wheel in-bed hitch
  • Air-Ride air bags
  • Cold Air Intake
  • 17,500 miles
Kilroy is offline
post #7 of 22 Old 01-26-2010, 03:24 PM
05_PSD_Erik's Avatar
Yes, the foglight mod will work on an 06.
I would not recommend the opening posters link as the Ford headlight is a dual filament bulb (hi and lo beam inside the same bulb) and I would think the bulb running both filaments would generate too much heat. Potentially damaging headlight assemblies or wiring.
Those boxes were a popular mod on GM vehicles as they run one headlight housing and bulb for lo beam and another separate bulb and housing for hi. So you don;t have any more heat than was originally intended to have. Hope this helps. All else fails, add lights like I did! (I have HID headlights, factory fogs, set of fogs in my grill, and a set of 7" driving lights on the bumper )
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #8 of 22 Old 01-27-2010, 03:28 AM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
see I was kinda of wondering that too, because even right now when I have the brights on for a while, I can literally feel the heat from the lens. I can't imagine what it would be like with both lights on.
For sure doing the fog light mod now.
04' F-250 6.0L
AFE Stage 2 intake
zoodad mod
Edge Insight CS
SWAMP's 48V FICM
Rotella ELC
scha0786 is offline
post #9 of 22 Old 01-27-2010, 05:21 AM
NEWT92's Avatar
I bought a used Bright Box from another member here last summer. Its for my 05 and is the full kit, high/low and fog lights. Works Great!!! Last fall, I done this mod Budget Brite Box on my 03 F250 (no fog lights) and on my 01 Grand Marquis. Also works great and makes a ton of difference having the high/lows on at the same time.
1968 Chevy Impala Custom Coupe ZZ4 350 700R4 trans 3.55 Posi
2003 F250 XLT 2wd. R/C LWB 7.3 Auto Volant Air Intake 4" Turbo Back Exhaust
2008 F250 King Ranch 2wd Crew Cab Short Bed V10 Auto
NEWT92 is offline
post #10 of 22 Old 01-28-2010, 08:47 AM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
and you have had no problem with burning out light bulbs?
04' F-250 6.0L
AFE Stage 2 intake
zoodad mod
Edge Insight CS
SWAMP's 48V FICM
Rotella ELC
scha0786 is offline
