fogs on with high beams canadian truck - Ford Powerstroke Diesel Forum
Old 01-23-2010, 03:08 PM
how do u do this on an 06 psd
Old 01-23-2010, 04:49 PM
Not sure if this helps, but might look at.
S&S Diversified
Old 01-23-2010, 04:54 PM
Fog Light OverRide
I don't know if it will work on your truck, but it did on mine and it has running lights (which i got rid of)
Old 02-01-2010, 02:55 AM
Powerstroke.org Acolyte
I also recomend doing a "brite box" mod so that high and low beams are on at the same time. I did that as well as kept my running lights, and supplied my headlights with power through extra relays on low and high beams. It is awesome how much more light there is now. Even on low beams. I have a switch that i can turn for stock or bypass mode. I'd say my low beams are 30% brighter with the relay bypass. Highly recomended!
I even had to adjust my lights down a bit because people were getting real pissed off at me with the extra power. Never had many people flash me till i did the mod.
I can post a diagram if you are interested.
Old 02-01-2010, 03:14 AM
Lifetime Member
Your diagram interests me Thank you
Old 02-04-2010, 02:46 PM
how did u get rid of the running lights?? i havent been able to figure it out yet. thanks
Old 02-06-2010, 08:33 PM
I just pulled the DRL fuse. It is labeled in the owners manual and it is a fuse all to itself, so if you yank it out it won't hurt anything else.
Also interested in the diagram
Old 02-12-2010, 01:08 AM
I got rid of my daytime running lights (DRLs) by pulling two fuses in the fuse box under the hood. Believe it was fuse #s 205 and 206 - check your owners manual to be sure - but it knocked out those DRLs. There's also a relay for the DRLs on the fuse panel inside the cab - pulled that and the DRLs were still working. So stick with the two fuses under the hood and you'll be golden.
