| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Hi I have a 04 super duty and my instrument lights, parking lights, door chime,mirror lights and cab lights stopped working. Sounds simple except i have checked all the fuses with a test light and visual inspection. I switched some relays to see if that would work. Nothing I also pulled the headlight switch out and put a jumper wire from the hot to the brown parking light wire. Every thing came on so its the switch. Sounds simple except i got a new switch and that has not solved my problem. Does any one have any other suggestions thanks
Was there ever a resolution to this? I'm experiencing almost the same problem.
One thing to check is the "GEM" module. I fried mine while wiring in some outside lights one time. Lost my park lamps.
