HELP: Headlight Switch Wiring Diagram
Ok, I have an '06 XLT that did not come factory with fog lamps. I bought the factory fog lamps, installed them, and put them on a toggle switch hidden under my removable dash panel (under the steering wheel) spliced into my driving lights 12V source. My Problem, now, is that I had a Remote Start/Keyless Entry/Alarm installed on my truck and the fog lamps would blow the fuse to my Viper system (duh) so I turned the toggle switch off. I'm not a fan of toggle switches being exposed that aren't factory so I've been cruising around with no fog lamps. I bought a factory Headlight Switch w/Fog Lamp switch to install and want to hook it up. I ran the 12V wire with one of my unused upfitter switch wires and already have it grounded. I'm needing the Wiring diagram so I can splice my 12V into the factory harness to use the new switch. Thanks in advance. God Bless!
