| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Clearence Lights
I just got a set of recon clearence lights and what was wondering what fuse I should tap into in the fuse box?
In the passenger side kick panel there is a plug with 2 wires that is the factory plug for the cab clearance lights. I tapped into that wire when I installed the lights in my truck. Just run the wire straight down the passengers side A-pillar to the kick panel.
I tried to locate the 2 wire plug in the passenger kick panel with no luck. So I am trying to find the wire to the parking lights to splice into on the headlight switch. Does anyone know where I can get a wiring diagram to look at or does anyone know off hand which pin it is on the harness itself?
Tap into the brown wire coming out of the headlight switch.
