radio won't turn on - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-08-2009, 04:35 PM Thread Starter
radio won't turn on
ok i tried to replace my stock 6 disc in my 04 f350 with a pioneer dvd. I hooked everything up and it worked. i forgot to hook up the speakers so i disconected everything and went back to the garage to hook up the rest of the wiring harness. then back to the truck to make sure it all worked and nothing! i checked the fuses and i had 1 poped so i replaced it and still nothing. i put the stock head unit back it and it lights up with the time, but won't turn on. all the fuses in the cab are good. can anybody help?
i posted this in 2 sections because i need an answer fast.
tbaer is offline
post #2 of 3 Old 12-08-2009, 04:54 PM
smokenstroke's Avatar
Quoted: 8 Post(s)
I know you said all the fuses are good in the cab but thats all i can think, my truck has 3 fuses for the radio,
-radio (main)
-radio (start)
and also the -(delayed accesory) fuse works the radio. I blew this fuse while changing my radio. If the radio lights come on and the time show up but it wont play or let you do anything thats most likely what it is.
Hope that helps bro!
2002 F250
Tunes
Intake
Exhaust
Turbo
Injectors
Traction Bars
smokenstroke is offline
post #3 of 3 Old 12-08-2009, 09:12 PM Thread Starter
yep thats what is was. the delay fuse. it kept blowing when i would hook the battery back up and then i figured out that the colors for the acc and battery from the head unit to the harness didn't match up they are opposit. wtf. 6 hours of BS and 4 fuse later. it's in and working.
now for a new problem how do i get around the "must apply parking brake to operate navigation or watch dvd/av" screen.
tbaer is offline
