- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
| Sponsored Links |
my 05 xlt with standard heat controls blows out of the defroster for a minute than blows out of the vents. There also is a vacuum pump on the right side next to battery that makes a terrible noise. Sometimes it stops,sometimes runs the whole time the truck is on. Anybody with that problem? the pump would be easy to change, but not sure thats the problem or not.
If your defrosters are all that work in both AC and Heat mode. It can be a relatively easy fix. On my 04 there is a vacume pump on the right side inner fender well. When I tapped on the unit it came on. So pulling it apart there is a set of points and an adjustment screw inside. Turn the screw an 1/8th of a turn or clean the points and you are up and running. Hope this helps. Ed
Next time you start your truck and the control panel doesn't turn on, try turning your lights on and off. I have had this problem with my 05 and I used to just shut the truck off and wait a few minutes but one day I just turned the lights on and off and the control panel started working again.
| Sponsored Links |
