Edge Insight Users - Ford Powerstroke Diesel Forum
Old 11-28-2009, 09:45 AM
Edge Insight Users
Okay, question for all of y'all that use the Insight. Is the "Module Volts" the voltage of the batteries, alternator, or what??
Old 11-28-2009, 11:40 AM
Old 11-28-2009, 02:21 PM
and another
Old 11-28-2009, 02:44 PM
Its what the PCM is seeing from the Alternator. You should be seeing low volts 10.8-12.5 during GPCM cycle...approx 1-1.5 minutes...then 13.?and up.
Old 11-28-2009, 03:43 PM
Thats what I was thinking and scared of. I am only seeing upper 12s at most. It will sometimes get into the 13s but its like 13.09
Old 11-28-2009, 07:59 PM
I tested my alternator and it was showing 14.2ish. So why are they different
Old 11-28-2009, 08:04 PM
BOSS LEVEL
what the same time when you were testing? you should see the same on both ends. unless the gps just turned off.
Old 11-28-2009, 08:10 PM
different time. I will check again in a minute
Old 11-29-2009, 10:57 AM
There may be some parasitic draw on amps from something before the pcm gets its reading from the alt?
Old 11-29-2009, 04:57 PM
What kind of volts are you seeing while driving?
