I purchased the Insight for $279 from one of the site vendors. Works great as I didn't want to spend the extra cash and time it takes to set up traditional gauges...does what I need and more. The SCT is a separate entity altogether....picked it up off craigslist from a local fella for $200. :thumb:
Honestly, I've never had it over 25psi...even before the Insight. I believe the dash needle is pretty accurate though...probably the only one...as you can atest to that since you're and Insight user as well. My boost has always been relatively lower than most I've seen on here, or I'm just not trying to kill my motor....lol. :thumb:
Where is Module Volts on the Insight? I'm having charging issues and could not find it in the menu.
At idle I'm getting 11.87 volts and at 2000 RPM is stays the same.
I am not for certain. If no one answers I will find out tomorrow morning for you.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
