Cruise Control Sticking - Ford Powerstroke Diesel Forum
Old 11-25-2009, 06:30 PM
I have a F-250 6.0 and while driving with the cruise set, sometimes when i hit the brakes the cruise doesn't shut off. After you stomp the brakes the cruise will finally disengage. has anyone ever had this problem? I would like to fix myself because i need a co-signer to get the dealership, haha
Old 11-25-2009, 08:45 PM
Powerstroke Techie
see if your brake lights come on right away all the time. What I believe is happening is that the brake lamp switch is sticking. If I remember correctly there is a pressure switch on the master cylinder that will cut it out if the brake lamp switch fails but it requires much more pedal pressure to activate the pressure switch hence the stomping on the brakes to disengage the cruise.
Old 11-25-2009, 08:50 PM
Real Men Love Jesus! <><
isnt there a recall for this??? I know I have gotten a letter, although mine has never stuck once that I know of.
Old 11-25-2009, 08:55 PM
Powerstroke Techie
yeah the 7.3's have a recall for the pressure switch leaking and potentially starting the truck on fire. no problems with them sticking though.
GO GET YOUR RECALL DONE. It's FREE!
Old 11-25-2009, 09:05 PM
I will as soon as I can get it to the dealer when i have time. Maybe Monday
Old 11-26-2009, 03:22 PM
cruise control sticking
how do i find out if the brake lamp is sticking
Old 11-27-2009, 08:13 PM
Powerstroke Techie
I usually back up against something that I can see the light reflecting off of and pump the pedal a few dozen times. or if you have a brake controller that has an indicator light on it you could watch that, or if you really wanted to get creative you could hook up an indicator light in the cab to the light green wire at the switch.
