rear window not opening all the way - Ford Powerstroke Diesel Forum
Old 11-20-2009, 06:18 PM
My back window does not open all the way, it seems like it is haveing a hard time opening. I checked to see if there was something putting it in a bind but cant find anything. Could the motor be going out and if so how hard is it to change out
Old 11-22-2009, 11:56 PM
theyre not hard to change. you have to pull the carpet looking stuff from behind the seats to get to it. try oiling it first.
Old 11-23-2009, 03:35 AM
Dry lubricant sprayed in the little groove the window slides in helped mine tremendously. I think they just get bound up from dirt, worn felt, etc.
Get some dry lube teflon and spray the upper and lower tracks.
Old 11-23-2009, 03:36 AM
TAG YOUR IT DAVEY!!
Old 11-23-2009, 07:41 AM
thanks for the info, will try it out when i get a chance
Old 11-23-2009, 09:33 AM
Originally Posted by HeavyAssault View Post
TAG YOUR IT DAVEY!!
That's about a photo-finish post!
Old 11-23-2009, 09:36 AM
You got it by a nose...
Old 11-27-2009, 12:37 PM
I am having this same problem. What kind of dry lubricant have you guys used?
Old 02-04-2010, 05:11 PM
Went out today to get the truck all cleaned up from the winter and was wondering the same thing?
