Radio delay shutting off - Ford Powerstroke Diesel Forum
Old 11-13-2009, 09:52 AM
My 05 F350's radio will not shut off for at least 15min after the key is removed. Anyone know waht to check,change or adjust?
Old 11-13-2009, 09:55 AM
Does it shut off when you open the door? That's the way my 06 is but if you open the door it shuts off immediatly.
Old 11-13-2009, 09:57 AM
No, thats what I mean it stays on for long after the door is closed locked and key removed from the ignition
Old 11-13-2009, 10:00 AM
Might be a problem with the switch in the door. Does your dome light come on when you open the door? Maybe try opening the passenger door instead and see if the radio turns off then.
Old 11-13-2009, 11:17 AM
Still the same problem?
Old 11-13-2009, 12:15 PM
Hmmm... Bump
Old 11-13-2009, 12:20 PM
So you shut down, remove your key, open your door, get out, close your door, lock it, and the radio is still playing?
--Snake
Old 11-22-2009, 10:55 AM
I have a similar problem. My radio shuts off when I open my door, but when I use my Viper turbo timer, the radio comes back on about 10 seconds after I take out the key. I'm not sure it ever turns off. I look forward to see what you find out.
Old 12-02-2009, 06:22 PM
I just bought an 04 the other night, never owned a ford, I thought this was normal. I am having the same problem, radio stays on, window and door lock switches illuminate, no dome light, no door buzzer. I will look at the door open switch when I get time.
Old 12-04-2009, 02:18 PM
Ford dealer replaced my instrument cluster when they took the truck in on trade, I did not ask why they replaced it. They ended up reprogramming the instrument cluster to get rid of the problem, everything works as intended, even the number 5 injector that failed on me yesterday morning on my way to work.
