Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 10-21-2009, 03:44 PM
chasee69 chasee69 is offline
stereo install and keeping rear seat entertainment
i want to install a aftermarket double din dvd unit into my 05 excursion. is there a way to do this and keep the rear dvd player working?
Old 10-21-2009, 11:43 PM
metstroke06 metstroke06 is offline
Strokin' N Smokin'
Is it the stock dvd unit? If so, I believe you can't... if it's aftermarket with the appropriate input they can wire a connector between both units and they can sync up...
Old 10-22-2009, 06:48 PM
shadowchrome shadowchrome is offline
I just went through this w/ my '05 and it will work. I came across this when I was researching this subject:
"05’ Ford F-150 Factory DVD audio to Aftermarket headunit. ***CAN system!
First, if your factory radio’s Aux plug has a Green/Black wire all u need to do to turn on the factory DVD player is tag that wire to ACC then find your audio on the Aux plug and wire up your headunit with the wire harness like usual, if not you must leave the radio in the car somewhere and do the steps below.
Hardwire your speaker wires and pwr, gnd, acc from your headunit to the wires listed below. YOU MUST CUT THE SPEAKER WIRES FROM THE PLUG!!! If you leave the speaker wires in the big plug it will put the radio in protect. On the small Aux plug cut the Aux wires listed below and wire them into RCAs. Wrap factory headunit in carpet and tape to protect it them mount it in the space behind the dash( if you have a aftermarket double-din this method wont work. You will have to take the radio apart down to just the board and heatsink to be able to fit it correctly!). With the radio plugged in PRESS THE AUX button that turns on the factory DVD player, this will have to be left on Aux ALL THE TIME so be careful that it wont get bumped. Plug in both the big plug and the small Aux plug to the factory radio. Secure the radio. The method that worked for me was to have the plug side of the radio facing the driverside, it took some spinning but it worked. Run the RCAs you spliced into the Aux wires to the Aux in on the headunit and you are good to go! All DvD funtions can be done through the factory dvd player so just leave the factory player in aux/dvd mode. Im not sure if the headphones will work im assuming they won’t. Also I’ve heard the video signal wires at the24 pin plug behind the factory DVD player are (+) Yellow and (-) Black if you wanted to splice them into RCAs and run them down.
Radio 12V- lt. green/purple (20A)
Radio Ground- black and black/lt. green
Radio Ignition- pink/black or lt. green/yellow
Radio Illumination- lt. blue/red (dimmer)
Factory Amp Turn-on- dk. green/purple
Left Front Speaker- (+/-) orange/lt. grn - lt. blue/wht
Right Front Speaker- (+/-) white/lt. grn - dk. green/org
Left Rear Speaker- (+/-) gray/lt. blue - tan/yellow
Right Rear Speaker- (+/-) orange/red - brown/pink
Aux. Audio Input Left- (+/-) gray - org/black *Wire into RCA the Aux into aftermarket radio
Aux. Audio Input Right- (+/-) purple - green/red *Wire into RCA then Aux into aftermarket radio"
This will power up the unit & it will work w/ the wireless headphones by only connecting the green/blk wire; if you want to run it through the speakers you will need to do the RCA plugs.
